Bob designed a great, light steel fuselage and aluminum wing. I wouldn't change a thing. He also seems to have fallen for composites. Bob also likes to "roll his own". How about female molded kevlar skins for the BH. Kevlar is 1/3 the price of Oratex. Once the molds are made, the labor to make each one is very low.
Oratex, unpainted is about 5 oz/sq yard. The lightest kevlar I can find is 1.7 oz (2.6 finished with epoxy) and 5 oz (7.5 oz). You could use the light stuff in areas not likely to get damaged, the heavier in areas of heavy abrasion.
Kevlar needs to be female molded. Sanding makes a mess of kevlar. But it is almost unbreakable. It is so difficult to cut, as dry cloth, you need special scissors.
I would love to do it myself, but my building mission is to get it built. Not create side projects. I would be customer #1 to buy a set of fuselage skins.
I am thinking about the 1.7 oz clothe on control surfaces. It would save a little weight, but would save 2 or 3 times as much in lead you wouldn't have put in the control surfaces. And, it is 1/3 the price of Oratex.
I would cover 1/2 the fuselage with Monokote, and heat shrink adhesive backed covering for model airplanes, then I would cut 1" foam to wedge between the stringers as a backing for the monokote to keep it from sagging between stringers. Then I would use 5 oz fiberglass over the monokote, let it cure, then another layer of heavier cloth. Then some foam of some type as a "core", then a last layer of medium cloth to make a light but rigid mold. Remove it from the airframe, and surface the inside of the mold.
