I didn't run the low tank all the way dry. There was nothing showing on the gauge in the three point attitude so there wasn't much in the tank, but enough to keep it running. Wings level or empty tank high didn't make a difference. The engine ran with no hiccups. It wasn't until i went wing low on the low tank that I got it to quit, and then only after several seconds.
With such little fuel in the tank it wouldn't take much to unport. I did a few shorter sloshes and there was no issues. The lines would have definitely unported for a few seconds but I guess the fuel replaced the air quickly enough that the engine was never starved. I do have a mechanical pump with a vapour return circuit so that may have got rid of the air instead of sending it on to the fuel distributor.
It seems like there's at least 15 seconds in the lines at low power settings. In fact the math supports it. 5' of AN6 line at 5 gal/hr should give about 12 seconds of fuel. At idle at 2 gal/hr that's 30 seconds. There's about 5' of fuel line above the level of my engine mounted mechanical fuel pump in flight attitude so it seems this is probably about accurate.
