The following posts are relocated from a discussion about mounting floats, to make it easier to find and discuss.
Fuel Flow Discussion, Moved from Float Mounting
I had a hard landing after an engine failure late last year. This is a Quickbuild bearhawk and we did not reinforce any of the fuselage. We followed the suggestions of Clamar and Mark WhatsApp Image 2019-09-29 at 1.10.04 PM (4).jpeg . Ripped the floats off but very little damage to the fuselage. WhatsApp Image 2020-01-17 at 8.46.26 PM (1).jpegYou do not have permission to view this gallery.
This gallery has 1 photos.Last edited by MattS; 01-17-2020, 08:08 PM.
Originally posted by MattS View Postshort story; Running on "Both" without having interconnecting tanks. Pressure differential between the tanks caused fuel flow stoppage.
And since fuel related issues are the #1 experimental problem, it's worth discussing.Last edited by zkelley2; 01-23-2020, 06:39 AM.
- Likes 4
It's more or less exactly what he said. If you have a fuel pump and have a both setting on your fuel selector, you need to either a) never use it in both b) have a vent line running between the two tanks towards the top of the tank to equalize the pressure in the air above the fuel. I could do some math with it later to show how that happens, but that's what's happening. You can have one tank empty and the other tank completely full and not be able to get any fuel to the engine.
Every certified aircraft has this if they have a both selector. They are required to by FAR.
Ok, zkelley2 I admit, I don’t get it. If the fuel tank is vented through the tank caps, what would a vent line connecting both tanks do for you that the cap doesn’t already do? The only failure scenario I can think of is to have one cap vent hole plugged. If that happens the fuel won’t drain out of the tank with the plugged cap and an alternate air source would be necessary.Last edited by alaskabearhawk; 01-25-2020, 01:30 AM.
Originally posted by alaskabearhawk View PostThe only failure scenario I can think of is to have one cap vent hole plugged. If that happens the fuel won’t drain out of the tank with the plugged cap and an alternate air source would be necessary.
