Hi Everyone,
I have had a lot of people expressing an interest in the Bearhawk Tundra Tailwheel. So I tasked Bob Barrows with designing a Tundra version of his famous Bearhawk Tailwheel. A couple of changes were made to accomodate the larger and wider tire used on the Tundra and to strengthen it to take more abuse.
First the wheel had to be made 1" wider to accommodate the wider tire.
Second, the forks had to be spread wider and also made longer to account for the 12" tire diameter.
Because of the added stress on the forks, Bob increased the wall thickness on 4130 tubing used to make the fork assembly and the fork cross tube at the top.
The kingpin had to be angled slightly more as we found the larger tire wasn't clearing the Round Tailspring rod on the Patrol version, when you turned it all the around backward.
The forks are designed to leave only a 1/8" to 3/16" gap between the tire and the forks and between the cross tube and the top of the tire. This helps prevent you from getting rocks jammed in there and locking your tailwheel up when you are doing those riverbed landings.
Lastly, if you look closely at the tailwheel body, you will see that we've added a friction adjustment device. Its a Bronze bolt with jam nut. If you find that you are getting some shimmy on asphalt, you can slightly tighten it and create a little more friction in the pivot. That will reduce the tendency of your tailwheel to shimmy.
I am not quite ready to start selling these yet. I have shipped the prototype of the Bearhawk Tundra Tailwheel to Bob for testing and his approval. Bob should have it next week, so anyone attending Bob's cookout will be able to see it in person.
I am hoping to start offering these for sale in November or December, depending on how well the testing goes.
I will post up another announcement to the group when I am ready to start offering these for sale. I just wanted to let Y'all know that I'm working on it as promised. see pictures below.
