I’m having an issue with clocking the Gascolator with the fuel valve when the union between the SPRL fuel valve and the Gascolator is torqued to spec. The interface between the forward edge ring of the fuel valve and the mounting bracket doesnt sit flush on the forward edge of the bracket and the Gascolator isn’t “ clocked” to the fuel valve. If there’s a way to torque the union while the valve, bracket, and Gascolator are in place but not fully tightened down, this might help seating the valve on the mounting bracket. Another option might be to put spacers on the valve side and/or the Gascolator side to even things up for a flush fit of the valve on the bracket. The mounting bracket is the “ new design” that doesn’t require a plate between the frame tubes
Thanks, jt.
Thanks, jt.
