Hey folks
Pretty specific title, i know. Here's the problem:
I have an O540-A1D5 with Bendix SL6N-204 mags. I also have a Garmin G3X system using the GEA24 engine interface system. One of the default sensors you can use with this setup is the UMA T1A9 Hall effect rpm sensor. It screws into the vent hole on the mag.
During my first engine run (and subsequent runs) it is showing an rpm of 0. I triple checked that the sensor is wired as per the Garmin install manual and the sensor drawing. Nada.
So i thought that in the years since i bought it i must have damaged it somehow so i bought a new one.
Same deal: 0 rpm.
The configuration of the rpm channel in the G3X is correct (checked multiple times), and the writing is correct.
Anyone out there have the same problem at some point, and if so, did you figure it out? I'm hoping it isn't an internal with the GEA24 as the warranty is long expired even though last Thursday was the first time the engine was run.
Thanks in advance
Same deal: 0 rpm.
Thanks in advance
Glad to see you’re getting close.
