LSA Status update: fuselage start through tail feathers
  • LSA Status update: fuselage start through tail feathers
    PDF log can be found here https://www.dropbox.com/s/p9v1iettu4...elage.pdf?dl=0
    On to seats and controls.....
    Wow, Awesome progress!!
    Stephen B. Murphey
    Bearhawk LSA
    Building #L-089
      Very nice! I'll be starting soon...
      BH733
      LSA23
        Thanks for putting that out for us, a great resource - especially with your notes. I just got started looking at it, will need to return to it.
          Well done, thank you for taking the time to put that together.
            Wonderful documentation! I'm wondering what filler rod and dia. you are using?
            Thank you!
            • BTAZ
              BTAZ commented
              I used 1/16 rg-45 for filler
            Great resource!
              hey BTAZ i have the tubing kit as well and I have just began to fit the upper frame together, On drawing 14 it shows a 1 3/4 offset between stations p and n. That causes a bend in the longeron. How did you deal with this bend? Did you prop up the longeron at station n with a 1 3/4 block? Thanks
                The top is built flat on the table.
                The 1 3/4 dimension is established when you put the top over the bottom frame and the side verticals set it.
                Basically, when the bottom "Level Datum" from C to D is on your level table, and the side uprights are installed, P to N will have 1.75" difference.
                Assuming your tubing kit is as accurate as mine was, it is basically "self jigging".
                  Thanks for helping me avoid a major screw up, I'm sure ill have a million more questions before this is all over.
