Covering fabric material for the LSA
  • Covering fabric material for the LSA
    How much covering fabric material for the LSA should be ordered?
    Dan R.
    And does it make any difference which system you're using to cover? (Stits vs Stewart vs Oratex vs ???)
    Jim Parker
    Patrol Quick-Build Serial # P312
      I'm using Stewarts System and ordered 32 yards of 2.7 oz. Superflight and another 2 yards of 3.7 oz. for the seats. I'm not sure what Oratex quoted but can look tomorrow. When I saw the price was nearly double I went with the Stewarts.
      • JimParker256
        JimParker256 commented
        Did you factor in the cost of all the fluids, renting or purchasing spray equipment and booth, etc. when you analyzed the cost? Would you mind posting the cost of the Superflight, paint, etc. that went with the Stewart's System when you post the Oratex cost? I'm trying to think this through. and leaning somewhat towards the Oratex system, but cost is always a concern... It would be good to have a "real life" comparison.
      • interstate al
        interstate al commented
        Here is a copy of the quote I received back in January. I did not factor in spray equipment as I already have adequate equipment. I will build a temporary paint booth in my shop and dismantle when done. With the Stewart's system I did purchase certified material. There could be a cost savings by purchasing non cert from Spruce but their rolls are not as wide as the certified? And the savings wasn't enough to get me excited. My total for the Stewart's was 3000 and change which included the top coat price. I ordered everything but the top coat and will order it when ready. And when I settle on a paint scheme?
        Again, I like the Oratex however would rather put that $$$ into other areas on the build?
        ALL PRICES ARE SUBJECT TO CAHNGE WITHOUT NOTICE
        Better Aircraft Fabric
        4621 Caravelle Drive
        Anchorage, Alaska 99502
        United States
        Tel: (907)261-8928
        Fax: (888)633-1684
        www.betteraircraftfabric.com
        Bill to:
        BearHawk LSA
        Estimate number: e-235
        Estimate date: January 21, 2015
        Expires on: February 20, 2015
        Grand total (USD): $6,596.70
        PRODUCT QTY PRICE AMOUNT
        14-010-090 White 6000
        Oratex 6000 Fabric Insignia White 900 mm (34.5&quot X 1 M (39.37&quot
        5 $76.95 $384.75
        14-010-180-001 Oratex 6000 White
        Oratex 6000 Fabric Insignia White 1800 mm (71&quot X 1 m (39.37&quot
        30 $153.75 $4,612.50
        15-010-050 Pinked White
        Oratex Pinked edge tape 50 mm (2&quot X 25 m (82')
        7 $149.95 $1,049.65
        0987 Adhesive Separate 1L
        Oratex Dispersion Hotmelt Adhesive 1 Liter - Separate
        Components
        4 $118.50 $474.00
        0948 Felt Blade(large)
        Oratex Felt Blade 10 X 14 cm (4" X 5-1.2&quot
        1 $15.95 $15.95
        12-100-002 Release Paper
        Release Paper 60 cm X 2 m
        1 $4.95 $4.95
        08210 Cleaner/Concentrate
        Oratex Cleaner/Concentrate 1 Liter (.264 gal) container
        1 $32.95 $32.95
        08240 Oratex Wax
        Oratex Fabric Wax - enhanced luster, color protection, and
        cleaning ease
        1 $21.95 $21.95
        ESTIMATE DOES NOT INCLUDE SHIPPING AND HANDLING
        CHARGES
        Total (USD): $6,596.70
        Grand Total $6,596.70
        BEARHAWK LSA
      I was reading on the Zlin website, they quote the Oratex as saving 8kg on their airframe for an added cost of $4,500
        I'm not leaning toward any system at this point, but from recent memory I learned that with the Oratex quotes, one should consider that their fabrics are pre-painted at the factory, you can make your own tapes from the scraps, and you can opt for fabrics out of their 2nd-rate inventory to knock the quote down further. You just might get some cosmetic blemishes, for folks who care mostly about function and don't mind if it looks like the fabric has been flown already. I'd have to see it in person to see the extent of this blemish-ness.
