Couple of questions:
1. What does the factory use?
2. What are the options?
On the LSA scratch build, plans call for 3/32 Monel pull rivets on the aileron nose and trailing edge.
Googling suggests Monel is a nickel alloy and I wonder why this is called for?
Plans do not specify flush but that seems what everyone is doing.
I am considering using Cherry Max CR3212 I think has aluminum sleeve and steel stem.
Not available in 3/32 diameter. But I think I might benefit from drilling out to 1/8 anyway.
Also planning on using the Avery pop rivet dimpler in addition to squeezer.
Thanks for any ideas and suggestions!
