"C" Case vs O-200 Dimensions
  • "C" Case vs O-200 Dimensions
    I have been offered the use of a Continental "C" crankcase and two cylinders to use when making the engine cowling. I think the "C" case will fit the O-200 engine mount but will need spacers to make the case long enough to use as a dummy for the cowling. How about some advise on this. Thanks. Rolly
    Yes, I used a C-85 case. Stinger
      Great fotos Stinger! Did the "C" case work without spacers? If not, what size were they? Rolly
        Rolly, The case dimensions for the c-85 and 0-200 are the same. I made steel spacers only to take the place of rubber mounts for welding. Stinger
          Thanks for the info/ Rolly
