I am a GRT guy all the way, love their stuff. I pulled all my old school round flight instruments out of the S-7 a few years ago, and replaced them with a Mini flight display, and saved some weight plus extra room in the panel. Put in a carbon fiber panel while I was at it, more ozs. saved. I have never missed my old steam gauges, not for a second, thought I would!
Back in the Game
I thought I was going to by Advanced or Dynon, and still like their new wiring solutions. But talking to them, Garmin, and GRT (one guy, LOL), I went with GRT. Haven't flown it but playing around a bit, I really like it. I REALLY like the new Dynon/Advanced wiring solution that NEV used. That might have swung me the other way.
I'm finally back to working on the LSA!!! Again
After having Covid at Christmas and all the catch up from being down, progress is being made again. Fit and fabbed parts for the rear windows install, drilled in place, deburred. Just need to rivet in place.
Hope to be covering the fuselage soon. My reasoning is painting in an open hangar is best around April in these parts.
Figure I'll get the fabric and paint done on the fuselage then do boot cowl, electrical, and engine install.
- Likes 4
One thing I would have done differently on mine(for the rear window frames)is to put the rivet shop head(the end you upset) on the inside instead of the outside. When I shrank the fabric, it touches the end of the rivet and show up as small bumps in the fabric. If I were to do it again, I would use flat head rivets installed from the outside.Originally posted by PropMan View PostI'm finally back to working on the LSA!!! Again
Is this a cosmetic issue or have you had wear in those areas? Thanks for the heads upOriginally posted by BTAZ View Post
Lots of parts going back on for what I hope is the last time, prepping for Fabric covering soon.
Also doing a bit of weight reduction, shaving off ounces hoping to lose a few pounds in the end. I wanted a removable rear control stick, so why not make it aluminum, 2.1 ounces less than 4130. Drilling lightning holes where possible, using thin washers, shortest possible bolts, clevis pins instead of bolts where shear loads allow.Last edited by PropMan; 02-15-2022, 10:12 PM.
Any time spent with a hole saw or a Uni-bit, is quality time! It pays off in satisfaction years down the road, every time you look at a part you spent a few more minutes on lightening, it has for me anyway. I have holes in my S-7S where no one else has, my thinking is the kit company stamps the part out, and they are done. That doesn't mean you can't put holes in it! The fun part is being smart about it of course. Also, when your plane comes out heavier than you wanted, (a given...) it helps a lot to know you did all you can to keep it light as possible.
- Likes 4
Well, here's a point where I add some weight, been debating this with myself for a while. Gonna install a small cargo "hatch" for two reasons. 1. Make servicing ELT and controls that are behind the cargo area easier 2. Loading things behind the rear seat will be easier also.
I call it a hatch because not putting hinges, using quarter turn fasteners. Seems the lightest and clean aerodynamically. But still quick to openAttached Files
- Likes 3
The Hatch opening mostly done. Need to deburr and rivet. .025 was used for the outer ring and .020 to form the angle pieces. Two tabs were welded for lower attach point, aft attach is an existing tab for rear baggage closure and upper is simply drilled to stringer.
I'll weigh it before installing permanent just so I know what it cost me, other than a day of work an a few scraps of metal.
My initial thought is to use Dzus fasteners for the cover. Any other ideas are welcome.
One suggestion.
When I shrank my fabric, it wanted to "roll" the bottom of the window frame out. I needed to reinforce it so(since the fabric was on I wasn't going to weld) used an Adel clamp on the diagonal tube that is roughly at the center of the window frame tied to a small aluminum bracket connected into the stringer that runs under the window frame.
I would suggest welding another "stringer standoff" to the diagonal tube at roughly the center of the window frame to better support the stringer against the tension of the fabric.
I recently installed my tail inspection frames and covers. Your cargo opening looks similar in design. Your material is exactly what I used for the frame and cover. Follow Stewarts Systems advice and attach your frame to your fabric from the inside after the first shrink to 250. After the glue cured an X is cut and fabric pushed through the frame, wrapped around and glued from the inside. The frame gets encapsulated.
If you choose to install quarter turn fastener receptacle after you cover & wrap, you eliminate obstructions from allowing fabric to adhere solid without those obstructions. After this photo was taken I riveted (squeezed) 4 tinnerman nut plates in each corner of the lower frame. It worked out nicely.
I also applied a zinc chromate coating to these frames. The AL gets roughed for a Stewarts Glue mechanical bond. I wonder if the AL might corrode over time and loose glue adhesion. So I roughen it, clean it, Chromate it, then glue it.
Screen Shot 2022-02-21 at 1.45.04 PM.pngLast edited by Bcone1381; 02-21-2022, 07:09 AM.Brooks Cone
One of the mods I did on both of my S-7 builds, was a aft baggage door, no regrets. It allows me to get into the area behind the baggage area, where I can keep light gear like a mattress pad, pillow, anything light but bulky. I also put a "ski hatch" in the plywood bulkhead at the rear of my baggage compartment, good for carrying 10' long PVC conduit, or a 78" Prince prop, both which I've done. Good advice on the fabric tension pulling things out of whack, as usual any mods lead to extra work!
Ok, got it done except for attachment and camloc fasteners, After seeing how much Camlocs are I elected to hinge it. Now we'll call it a doorLast edited by PropMan; 02-21-2022, 09:17 PM.
