Sorting out wires
Back in the Game
Finally was able to paint the tail parts. Had time and good weather.
- Likes 4
Baffling Baffles!!! Gettin it done.
Paint looks great!
Way prettier than my oratexN678C
Just when I get rolling on one part I realize something else needs to be done to complete the first task. Lol
Wiring stopped to get baffles done so I can terminate engine monitor wires properly, then I realize the cowl needs to be done for the baffles. It's a vicious cycle. But will be done SOON!
That cowling has taken me about 2-3 months when you figure in all the little details involved. The low pressure lip was 25+ hours. I am glad I am “nearly” done with the cowl, just a note, it takes a lot of planning.N678C
I Hate fiberglass work. Took all day to make the lower Windshield trim. But it's done except for final trim, filler and paint.
Almost forgot, Edging trim came in, finished the tail fairigs yesterday also.
Originally posted by David Swartzendruber View Post
What edging trim are you using and where did you get it?Brooks Cone
Rubber Edge Trim, 1/16" U Channel Edge Trim, EPDM Edge Protector, Length 20Ft, U Shaped Gasket, Black Color, Edge Protector for Sheet Metal - Amazon.com
this trim is rubber with no metal reinforcement. I do have some that is reinforced for the boot cowl edge over the panel but can't remember where that was purchased
More windscreen trim. Vertical side pieces. I bent them so a lip is formed for the window frame rest in the lip. Will add edge trim or foam as needed
