Back in the Game
Cowl parts painted ✔️ , all but nose bowl installed. Should be able to do that tomorrow. Then prop goes on. Yee Haw
- Likes 5
Props On!
I'll cut the spinner later, after AW cert is done.
covering ailerons and painting them now.
Door paint complete!
covering the ailerons, then paint later this week if all goes well. Short list is shorter?
Paint going on aileron #1, should have them painted and installed before Christmas!
waiting to see what day the DAR can come out after new year. Hope to be flying by end of January!
short list is real short!!!!!Attached Files
First start! Yee Haw Had to shut down, not showing oil pressure. Turned out to be instrument problem.
Oil temp and tach are working !
#3 valve cover gasket leaking.
All in all, a good day.
- Likes 7
I replaced the oil pressure gauge with a mechanical one, old school, and it works! Had to pull right baffle off to see what's leaking on the 3 valve cover. Was a torn gasket, thats 2 of 4, ugg. Sure wish they'd been more careful assembling, cost me an hour of work! Ran engine to verify gauge operation and check for leaks. All good now! Yee Haw. More to come
