FYI: While getting ready to cover my fuselage I was mounting my rudder to locate rudder cable exits through fabric. Although my rudder had been mounted before while making cables, etc the two hinge holes didn't line up. I pulled print 20 out and checked dimensions. Found out my print has the holes @ 38-3/4" c to c but my QB vertical stab has them welded @ 38-1/2". When I covered I used the print so was off 1/4". A Dremal tool and cut off wheel I was able to move it the 1/4".
So might want to check your measurements before fabric work!
