I searched the FAA's data base and found twelve Bearhawk Patrols. I have plans number 303 and am scratch building...still making form blocks. Does anyone keep track of how many get completed? I think the FAA gives a builder wide latitude in naming his aircraft type, so there may be more Patrol's registered here in the U.S. than the "twelve" in the database. Plus, there are those registered outside the U.S.
I was able to determine the engine type in ten of the twelve. The fleet is using almost exclusively an O-360 or IO-360. One has an O-320, and one O-375.
Here is the list I found
Names and registration numbers deleted by the author on 5/10/2015.
As I look over this information, I wonder what kind of props, equipment and empty weights each one has. Gaining knowledge is my goal to help all of us build a better Patrol, and increase the completetion rate.
If you have information on these aircraft, pass it along on this thread. I find especially useful "Industry Best Practices" that are based on scientific data.
