Everyone, I have mounted my right wing in the jig and have been checking the level and twist and squaring everything up. I have a plumb bob from the main spar to the rear spar mounting holes. Everything is perfect EXCEPT that when I check the level from the main spar down to the rear spar (1 1/2" spacer block taped to the one end of the level) I am showing 1/4" of twist in the wing from the root to the tip? Not sure what to do, any suggestions?  I also ordered my flap supports and aileron supports from Avipro and there are no grease zerks in them, is it necessary or can I just lube them up good during assembly and call it good to go?
Thanks,
Barry
					Thanks,
Barry
