SpruceForest
Scratch-Built Patrol SP
Carlo closed out his wings in July, and we are jigging up for fuselage work on both aircraft as he completes all his wing set's detail work (TE stuff; retract landing lights; flush mount on wingtips, etc.). I had a chance this past Tuesday for a brief visit after the local chapter meeting where Carlo's wife briefed her participation and past management involvement with the ARC Air Races. Good stuff that should show up on the chapter YouTube channel.
The fuel cells are close to bring buttoned up and pressure checked, and once that is done, set aside for fuselage work.
In terms of a summary for others contemplating the job:
- Don't even think about it without good engineering support and a wealth of wet wing build and repair experience. Also - the PITA/skill factor to get that riveting done with change in access to the LE box and tank area ups the bar... one of the reasons why I went with the plans-built tank design on mine, despite access to the engineering expertise and SME support
- Based on elimination of the separate fuel tank and addition of structure to handle the higher inertial loads on the lower skin and internal ribs, Carlo expected a very moderate reduction in weight - something like a 5 lb reduction in weight - and increase in fuel capacity to 31 gallons per side, with final capacity and delta weight TBD.
- The major structural changes were:
- - Retaining the wing ribs through the tank area as load-carrying structure and anti-slosh baffles, with an additional rib to create four bays and keep loads reasonable
- - Skin joints moved outboard of the end rib of the fuel bays and a triple rivet line inboard to spread the skin loads
- - Extension of the 032 upper surface aft-spar-to-lower-surface-main-spar skinning out to the ends of the fuel bays
- - Lower skin aft of the main spar to 040 through the entire fuel bay
- - Elimination of separate fuel tank mounting hardware (and elimination of the concentrated loads from that hardware on the main and stub spar)
- - Elimination of the main spar lightening holes within the fuel tank footprint (with associated added complexity of bucking the LE skin rivets and wet riveting the cell!!!)
- - Addition of the 063 milled upper surface inspection ports
- - Addition of weight from all that ProSeal on all rivet lines internal to tanks
Again - not something to be contemplated lightly, but the weight reduction, elimination of some complexity on the structural side (those concentrated loads from separate tanks), and additional tank volume made it something Carlo saw as desirable.
The pic shows the access panels off and vent system install being wrapped.
Re: feedback: Bob found the project interesting, but was not going to endorse or review for obvious reasons. Mark wisely repeated the mantra of 'build to plans.' Without Carlo's background (adult life as as working A&P-IA; multiple scratch-built show plane wins at Oshkosh, etc.) and his available engineering support, not something to consider.
