It looks like from the plans - that the trim shaft has to be put inside the ribs before the ribs are welded into the leading and trailing edges----- as the smal horn get welded onto the outboard end of the shaft- and there appears to be no way to slide it in or out -----
if that is correct--- why couldnt I just weld the horn to a short piece of the bushing material so the horn assy. and the shaft could be cross drilled for a small bolt---
that way the shaft could be slid into the stab at a later time------
Tim
I will check Eric's CD for that detail tomorrow-----
Tim
