So if someone put a small turbine on a patrol like the rv 10 has how fast could it fly ? Is it a structure issue or a control issue at a higher speed ?
Patrol Airspeeds
Speed has little to do with horsepower and most to do with drag. I'm sure you'd gain a good many knots if you cruised in the upper teens on o2, but down low where these airplanes normally live it'd be a rather small cruise increase and a crap ton more fuel burn.
I sat right seat in a C206 Amphib with the Soloy turbine conversion. I could not believe the acceleration and climb angle! When asked about speed, the owner explained that the original VNE still applied, so as long as it wasn't 'indicating' past red line - you were good. Might be good up really high, but I sure wouldn't want to be at VNE down low in the bumps.
It WOULD be fun to have that takeoff thrust and beta, though!
I am getting ready to have the arcs on my airspeed indicator labeled and I am not seeing any full definitions in the forum. I have the white arc as 41 to 100 mph, max flap speed. The green arc is 48 mph to Vno which I haven't seen defined. The Yellow arc would go from Vno to Vne, the never exceed speed. Anyone have suggests for these missing numbers?
Originally posted by spinningwrench View PostI am getting ready to have the arcs on my airspeed indicator labeled and I am not seeing any full definitions in the forum. I have the white arc as 41 to 100 mph, max flap speed. The green arc is 48 mph to Vno which I haven't seen defined. The Yellow arc would go from Vno to Vne, the never exceed speed. Anyone have suggests for these missing numbers?
To find Vne, we need to ask Bob. If you get through please feel free to report back. I tried calling just now but he is busy. The Vne might be based on structural loads or something else like flutter considerations.
The yellow arc is a little harder. When I think about defining airspeed limits, I think about the V-g (V-n) diagram. Rod Machado wrote a nice series of articles about them with the first one being here:
The link at the bottom is broken but here is a link to the second part, which is the part that gets to the yellow arc:
There is a very good article here:
The Vans article is coming from the perspective of not oversizing engines, because routinely operating too fast reduces the margin. There's no way to know how strong of a gust you may encounter, so the closer you are to the edge, the more risk you take. The longer you fly at speeds approaching the edge, the more times you roll the dice.
Skip Smith wrote a very good article in the January 2006 issue of Sport Aviation, which you can search for on the EAA archives.
Part of the problem with the yellow arc is that you'll need to establish some expectations and assumptions. You can decide on how much of a gust you want to be able to withstand, and at what weight. It is not possible to say "here is a single speed" at which the airplane is indestructible. Instead we have to decide on what is an acceptable level of gust and risk, which is a policy choice rather than an engineering choice. If you want to assume current TC standards, they are designed to handle a gust of + /- 50 feet per second at cruise speed and a + /- 25 fps gust at design dive speed. More here:
If you want to get nerdy about it 25.335 gives the formula for calculating some of these things. Naturally we aren't flying under part 25 with our e-a/b airworthiness certificates, but those numbers were probably arrived upon with some sound thinking.
I just dealt with this as Dynon is pre-programming my HDX and asked for speeds
I guessed but called Mark to confirm, I was very close but tweaked them a bit to be on the safe side
Companion so very similar to the Patrol
Vne 165
Vno 120 ( I was gonna go with 125 but Mark’s tone made me lower it to 120)
Vfe 100
Vso 38
Vs1 46
Hope this helpsN678C
