Mark Goldberg says something like "Perfection is the enemy of Completion."
I have assembled my shock struts, and filled them with fluid. I found some advice on the web that suggested and "Improvement" by installing and sealing a plug (a 1/2" 20 tpi allen head set screw) deep into the Shock Strut Rod before installing the Rod End Bearing. I may be guilty of jumping on any "improvement" that gets suggested. The plug is in place right now with out any sealant and is easily removed. When the strut is layed down horizontally, some leakage occurs over time as I would expect. I expect the same thing to happen after the Rod End is installed.
But why do I need to worry about sealing this end? After installation the Rod End threads will almost be the high point. The fluid is rarely under pressure, and I don't see it leaking out. So, now question the need for concern about sealing these threads tight. I see some have used EZ Turn in the past...fair enough. The amount of time that the fluid will be under pressure before reaching equilibrium with the spring is a fraction of a second I would guess. Seems like a pretty fool proof design the more I think about it.
But I want you who are operating this installation to verify this for me. I filled the strut by removing the filler port on the side of the strut cylinder, then poured fluid into the 3/4" tubing until it ran out the filler port which results I think in about 1/2" of air in the top of the strut. As long as the Patrol stays right side up, I can't see where this design is going to be prone to leaking fluid out these threads.
Am I missing something?
Kit Building Patrol #303
