I don’t quite see why the extra width or looseness is desired in the fork though. Mine pinches the spherical part of both rod end bearings very tightly, but the bearings still work perfectly, since the outer part of the rod end does the moving around the fixed sphere. ( 2nd pic). Am I missing something?
If it pinches the rod end bearing and you have a jam nut, thats not good. The rotation of the stick exceeds the rotation of the rod end bearing in this configuration.
This thread might help understand what we are talking about.
http://bearhawkforums.com/forum/bear...-stick-pushrod
A more lengthy response.......
The Control Stick’s Push-Rod connects to the idler arm with a rod end bearing. But there is insufficient room in the 7/16†fork for the .500’ wide bearing to fully swivel as roll inputs are commanded by the stick. As the stick is moved left/right, the rod end bearing also rotates until the bearing housing contacts the sides of the Idler Arm. Ideally, the rod bearing outer housing should not contact the idler arm as it swivels.
There are two ways to proceed. Some do not use a jam nut which allows the pushrod and rod end bearing to rotate freely when the stick is moved. This method requires annual lubrication of the threaded rod end/elevator push rod connection.
Others joggle the fork to create more space for the bearing to rotate. This joggle makes the fork wider to accommodate the bearing. We also placed a small bushing on each side of the bearing to secure the assemble tight with proper hardware and torque specs.
Here are notes I made for myself. To secure the rod end bearing to the lower idler fork, while allowing the bearing to fully swivel.
- Joggle the lower .750†of the idler arms out .125†each, opening it up to .750†in lieu of the snug fit on the rod end.
- Lock the rod end bearing to the control stick push tube with a Jam nut.
- Fabricate two bushings (1/4†x .028 x .120) to fit between the fork and the rod end bearing.
- Install the Rod End Bearing into the Idler Arm’s widen out lower fork, using the AN3-11A bolt , the two 1/4 bushings, and secure with proper hardware
You also may want to drill some lubrication holes above in the idler arm hinge mechanism above this rod end bearing.
The photo below shows a slight joggle in the lower fork and the bushings sandwiched between the fork and the bearing.
