What Lycoming O-360 for Patrol
    Excellent! Do you buy the switch setup as a pre-built unit from the company that sells the Pmags or do you have to engineer and build it yourself?
      Pmag doesn't supply wiring. It's very simple, a SPST toggle switch from aircraft spruce placed on the panel wired between the jumper leads.
      • #18
        Thanks. Anything you don’t like about the dual Pmag?
        • #19
          My plane has one Pmag and one regular mag. It's happened twice now on a start up after sitting for a couple weeks it runs really rough on the Pmag, shut it down for a few minutes and start it up and it's fine. Apparently it's due to condensation and isn't uncommon. I wouldn't fly without a Pmag or some other electronic ignition on one side and like having one standard mag for reliability.
          • #20
            I've been running dual p-mags for a few years and haven't had any trouble out of them. I'd install the same if I were building another.
