I finally got started with my build and it's generally going well. I hit a bit of uncertainty with the torque tube and the elevator push/pull tubes. There is not much info in the manuals and the plans on this. Some of the issues could be caused by this. Can I ask some of you Patrol builders to double-check my install and clarify things for me?
The front stick seems to be ok. I used an AN3-5A with only one thin washer and clamped the bushing from rotating with a low-profile lock nut. The stick is not perfectly centered but there seems to be just enough clearance for the bolt/nut not to touch the torque tube. I wish it had more clearance so the nut/bolt would be further from touching the tube. But I guess this is correct?
Then on the rear stick I have quite a bit of sideways tilt. When I simulate resistance the bottom of the stick moves enough for the nut to touch the torque tube. Basically the stick's hinge point has too much sideways play.
Video: https://youtu.be/1mKq37DWMU4
Also the push/pull tube is centered in neutral position but deflects quite a bit to the left on right aileron.
Finally the push/pull tube rotates on the rear aurora rod end thread. Is this correct and intended?
Video: https://youtu.be/ALl908nwA4Y
Appreciate your input and hope this is helpful for future Patrol builders.​
