I am a bit puzzled as to what's the best way to route the fuel lines. Specifically I am trying to figure out the details behind the pilot door. I am coming through the aft former and then possible have to go through two stringers. This seems to be very hard to do as one piece of fuel line. I would basically have to delay mounting the the formers, slide them on the already perfectly bent fuel. This would also make it very hard to replace the fuel line later.
How did you do this? Split up the line with a coupling? Completely bypass and just go around the inside? Then build some kind of protective cover over it?
Anybody has some good photos (preferably for the Patrol but I assume the 4-Place has a similar detail).
