I've been trying to contact Newton Consulting about their V1 fuel valve but the mailer daemon keep bouncing my email. The picture shows a fully seated orb fitting in their valve. These are the fittings that came with the kit and look exactly like what is sold for the valve on ACS. The o-ring is still visible where the cylinder of the body drops away from the fitting on either side and the compressed o-ring sits against the sharp edge of the machined port. Also, there doesn't seem to be a proper seat for the o-ring, rather it sits on the top thread
of the port as far as I can tell. Each port looks the same - I can't see that there's a chamfered seat for the o-ring. I used EZ Turn as a lubricant for the o-ring. Installed one of the fittings and removed it and my o- ring was shredded in the process. I tried another fitting and carefully reinstalled it and took the picture here. This can't be right, right?
