I recall airplanes with squeaks and rattles from the windscreen jiggling laterally across the cabin top and boot cowl. It was most noticeable on engine start and shutdown.
I have five 6-32 bolts holding the windscreen tightly against each vertical aluminum former at the rear of the windscreen, each bolted through an exterior trim, the window (with grommets) the former and/or steel mounting tabs, and a nut plate on the inside
. It feels like the top of the windscreen is inclined to “rack” side to side slightly in the double u-channel. Just a slight wiggle. I haven’t yet put acrylic sealant in to waterproof the joint, but I wonder if anyone has thru-bolted across the top of the windscreen, or the skylight for that matter too? How about the base of the windscreen?
On another matter, my boot cowl sides are detachable from the top, below the windscreen corners. I see no reason not to permanently attach the INNER windscreen flange to the boot cowl. Am I missing something?
Thanks.
Thanks.
