Material List BH5 Wings
  • Material List BH5 Wings
    My1st material order for BH5 wings. More flat bar for the rear spar caps & spacers is required. Fyi, One extra sheet of 0.020, 0.025, & 0.032 are included in this list. Otherwise this was my starting point for material procurement. Hind sight being 20/20, I would not order a full sheet of 0.062 I would simply substitute 0.125 for that material.
    Cheers to everyone
    20' 1/4 x 1/2 .125 6061-T6 Flat Bar
    6 4' x 12' .020 2024-T3 Sheet Aluminum
    7 4' x 12' .025 2024-T3 Sheet Aluminum
    4 4' x 12' .032 2024-T3 Sheet Aluminum
    1 4' x 8' Really only need about 3 square feet .040 2024-T3 Sheet Aluminum
    1 4' x 8' Really only need about 3 square feet .062 2024-T3 Sheet Aluminum
    1 4' x 12' Cut to make your own Main Spar cap strips .125 2024-T3 Sheet Aluminum
    3 4' x 12' .050 5052 Sheet Aluminum
    1 4' x 12' .032 5052 Sheet Aluminum
    60' 1/4 x 3/4 flat bar for rear spar cap strips & "Misc Stuff"
    List up Dated March 12,2022
    Watch out for scratches. The biggest problem I have had ordering raw AL stock. Telll your supplier that scratched AL will be returned and they will pay the return shipping..Aircraft Spruce was the worst offender.
    Patrol #30
      Source your material through a local metal distributor. It will come double side plastic wrapped. No scratches. Should not cost more then 5K tops. Only order through Aircraft Spruce as a last resort. AS are to expensive. Imho:cool:
