Left window stand offs
  • Left window stand offs
    Would someone with a recent bh5 qb measure the window standoffs for the rear d window on top? There are 2 and I am thinking mine are short.
    Thanks
    Travis M
    Kentucky
    Received December 2022
    Kit #14, not sure if that is recent enough.
    First picture is top front (back a little to maybe give some perspective), then closeup of top front, then top rear, then bottom
    This gallery has 4 photos.
    • FFTravism
      FFTravism commented
      Thank you that is exactly what I needed. Mine is #21 so not too far from yours.
      Travis
    Were you asking about this because it doesn't seem like you need the joggle piece that Colby and Colin used between the back left window and the D shaped back left window? It looks like on mine they are pretty much flush.
    And if so, did you just splice in a straight piece of aluminum to tie the two windows together?
      Pictures for better clairfication
        Yes exactly. Top seems flush on mine and the bottom could use a little joggle.
        Travis M
        Kentucky
          Same question. My frames sit flush. no need for joggle, but then how do i get the rear window out if the frames sit flush?
            I haven't figured that out yet. I have the same question.
            Travis M
            Kentucky
