New scratch builder
  • New scratch builder
    Hello I am an A&P IA looking to build the 4 place. I am embarking on the journey with my girlfriend and my stepdaughter. Both of them eat sleep and breathe aviation.
    What part of the country?
    Living near Aircraft spruce locations or Wicks makes life simpler.
    B-spot has a lot of videos
    Stan
    Austin Tx
      Welcome aboard scratch builder. There are lots of us here.
        As an A&P, you def have a leg up on the average builder. I'm fortunate to have paired up with an IA after the project started. Carlo is a career A&P-IA that has scratch-built a couple other airplanes, so he keeps me straight on acceptable practices/best stuff to use in the airplane and I handle the engineering questions on his mods (e.g., wet wing; Super Cub overhead flap system for Patrol) and some of the jig building/custom 4130 forming (aero engineer/woodworker). Having a family that thinks airplane stuff under the dining room table is super-cool helps... that in itself is a major win. Good luck going forward, and there is a lot of stuff here on wing ribs, etc. to get you going if you have not had a chance to do component fab since A&P school (assuming you were not doing mil stuff at depot or patching up combat damage).
          I am currently in central Pennsylvania. I am 50 years old and retired from farming. I started flights training after selling my farm and I worked as a GA apprentice while flight training. Now I run a small GA shop and my stepdaughter is my apprentice and my girlfriend loves helping me fix up my Beechcraft travel air. I figured this would be a great family project and I still have my farm fabrication and repair shop. Can someone direct me if someone has a file for a cnc router or plasma cutter to cut the wing ribs I’m not partial to sitting for hours on end with a hand snips.
            plasma cutter would not be a good idea.
            My snips probably date back to World War II. They knew how to make a great way of cutting sheet metal by hand.
            These snips are the way to go. You are only crudely cutting out the shape of the blank.
            Probably only a minute to do a rough cut within a 1/4 inch of the line.
            The only way to get efficeint placement of blanks is by hand.
            ​ This kind of snip would be horrible to useVVVVVVVVVVVVVVVVVVVVVVV.
            ​ This kind of snip would be horrible to use ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^.
            ​​​ This kind of snip would be horrible to use ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^.
            On ebay they are under the category of antique or retro
            e.webp​ You will have to stone them to get them back in working order.
            Then you take 4 or 5 crude blanks and sandwich them between two pieces of mdf then use a trim bit.
            The router makes the edge. At this point the blank is then placed on another mdf form and the edge is bent over
            mass production using a router with trim bit
            This will remove the jagged edge and make perfect duplicate blanks that will then be bent.​​​​​​
            Stan
            Austin Tx
            • sjt
              sjt commented
              Original post somehow dropped the picture of the tin snips not to use.
            No files... but keep asking. I keep promising myself to get things done up in Fusion, but building and our current excitement/'use the bridge while we rebuild the bridge' in the DC area gets in the way. FWIW, you have a couple Patrols being scratch-built and a 4A scratch fuse/kit wings in Frederick MD... not a horrible drive and an easy flight to visit. Carlo has his Patrol on the gear and nearly done wiring plus wings 90% done. I'm way behind him with buildup on the wings going on and the basic fuse weldment hanging in the garage. The 4A is in paint and getting close to inspection if not already there. Check the builder map for others in your area. Always amazed at what I get out of builder visits.
              Since introducing myself the girls have already talked me into the model five rather than the 4 because we have dogs to take with us. My stepdaughter is also considering the LSA or the patrol to build side by side with mine. Hopefully we dont bite off more than we can chew. I also wanted to offer anyone in the area I do really well with figuring out avionics so if any help is needed in that regard I would be happy to lend my knowledge and/or help
