For anyone considering using caulk to seal up their windows - be informed - the strip caulk (this stuff shown below) is a menace and a complete waste of time. Upon reading the manual, and in my ignorance, I confused this strip caulk with silicon sealant "caulking material" which I should have used.
Bad, bad stuff...
This stuff leaves you with an awful mess in the long term, and doesn't do the job it's supposed to do (seal stuff). It just gets warm in the sun, turns into a pseudo-plastic fluid, moves around with the pressure / vibration of flight, and ultimately makes a hell of a mess....
Of course, I didn't figure this out until too late. It is IMPOSSIBLE to clean up without nasty chemicals.
I have the caulk-strip crap all through sealed parts of my plane, and it is causing me a seemingly Sisyphean headache. I am slowly getting around to removing the stuff, and using proper sealing tapes or silicons to do the job right, the second time around. I am having to cover up some of the mess it left behind.
Consider yourself warned... carry on.
Bad, bad stuff...
