I have installed fuel lines from the the wing root, thru the tee and on to the fuel selector and gascolator but have not yet checked the system for leaks. What is the best practice for doing this?
Do I install a small balloon on one of the line at the wing root, opening up the fuel selector valve, and introduce compressed air (My compressor has a regulator. I would set the regulator at about 10psi to prevent over pressurization) into the system until the balloon is inflated? Will a balloon create enough pressure to cause a fitting to bubble up some soapy water if its leaking?
