i made templates for locating the fuel fillers for all the tanks. Cleco the template to the nearest rib and place a thin stick under the template. When you put the tank in it will slip into the template and then determine if that location is suitable if not you can adjust the cleco holes. If interested I will mail them to you just return them.
Templates for locating fuel filler for. Four place main and aux
This is located in the opening for the aux tank. The stick elevates the aluminum so when the tank is installed the filler will pop into the precut hole and then you can determine if the location is satisfactory. If not you can move on plate to where you want it and drill new cleco holesYou do not have permission to view this gallery.
