Templates for locating fuel filler for. Four place main and aux
  • Templates for locating fuel filler for. Four place main and aux
    i made templates for locating the fuel fillers for all the tanks. Cleco the template to the nearest rib and place a thin stick under the template. When you put the tank in it will slip into the template and then determine if that location is suitable if not you can adjust the cleco holes. If interested I will mail them to you just return them.
    Could you post pictures of this? Sometimes a picture clears up a lot of "grey area" for some of us...
    Jim Parker
      This is located in the opening for the aux tank. The stick elevates the aluminum so when the tank is installed the filler will pop into the precut hole and then you can determine if the location is satisfactory. If not you can move on plate to where you want it and drill new cleco holes
