Router template for nose ribs
  • Router template for nose ribs
    I am working on the MDF router templates for my ribs. I'm guessing this issue has been discussed before, but I could not find it with a search...
    The plans call for a 3/32 radius at the point near the tip where the flange ends. I certainly understand the reason for this, but as we all know, when these templates are duplicated with a router, the inside cut at this intersection matches the radius of the router bit.
    My question is, can I leave it this way, then cut my nose rib blanks with this larger radius in-place and bend the flange as it is? Or do I need to drill the aluminum blank at this location and cut or file it to match the depiction on the plans?
    Karl
    Northern Idaho
    I left it. It’s a large radius, so I’m confident it will be fine.
      Thanks Chris!
      It definitely simplifies it!!
      Karl
      Northern Idaho
        Maybe I’m splitting hairs here...but on the drawing it shows a partial inward radius before it has the outward radius ( j shape)at the point he is referring to.... I’ve seen this on many plans of different planes and I would assume it’s a stress reliever when metal is being folded over and over stressed in an un fluted state and a flange stops but the web continues... usually seen this on nose ribs in that location
        so.... I think he still has to add the inward radius stress reliever as per plans ....regardless of the size of the outward radius....
        the spot im referring to is the point you would usally drill to form the shape
          You could try it with just the router corner and see how it goes. If you don't like it then you learned.. No harm in that. But don't throw the rib away. User it to practice your first flutes, your first lightening holes, your first stiffeners, your first priming, etc. It's handy to have a piece to practice on and answer those "I wonder if this will work" questions that are bound to come up.
            I did mine with just the router bit--- but im using a 1/4 inch cutter with a top bearing. Cut my template to match the bearing (1/4 inch----)
            I placed the hole so it is tangent to both surfaces. (no reverse dip) I figured since my radius was bigger-- that I would be OK......
            T
