Any kit or scratch builder is susceptible to making the mistake I just made, so a public confession wouldn't hurt.
While riveting a wing skin to the nose ribs (poor access to the shop head) I apparently slipped the bucking bar off the rivet and caused a little dent in the skin. I removed the few rivets we already drove and used the Dremmel to remove the scratch on the skin, then realized I had slightly sheared the skin.
Lesson 1: always carefully inspect a ding in the wing skin
Now I'm ready for lesson 2, how do I fix this? My initial idea is to turn the area with a crack into a small hole. As long as I keep it away from the rivet hole, there should be no structural issue since we drill holes in the leading edge skins for other things like pitot tubes. Then I create a back plate and filler for the hole, but those will be cosmetic additions only. Make sense?
IMG_20190807_061834116.jpg-Nic
Scratch building 4 place #1217
