Cutting Acrylic
  • Cutting Acrylic
    Please school me on the best way to cut acrylic
    I initially used an air compressor powered jigsaw, but it was melting the edges a bit, …… then I tried the scoring method which was an epic FAIL.
    Please HELP
    A cut off wheel on a die grinder works well. Mark
      I scored it with a drywall knife with the break-away blades. I had a few slips but managed to keep it clean. I used masking tape for protection so I could put the straight edge on the good part. This way, if the blade slipped, it would hit the area that I was cutting off anyway. I clamped the straight edge down so I didn't have to worry about it moving.
      Start off slowly so you can get a nice straight line for the blade to follow. It took quite a while to get through. Keep the blades fresh and have plenty on hand. It's tough stuff and it eats the blades up.
      IO-470 - 260hp
        What Mark said. Way too easy, no breakages. You can do corners too. Then just gently run a file along the edges to tidy it up.
          Yep. What Mark and Nev said. I use a Harbor Freight 3" pneumatic cutoff tool. Cheap and works great.
          Lee
          Patrol QB #312
          Buchanan Airfield
          Concord, CA
            I found the die grinder a little too energetic and hard to control when I cut my RV-8 canopy. I'm a Dremel guy. I found a small metal cutting wheel with small teeth and that worked for me
              I used an angle grinder with a cut-off wheel (3/64" wheel for metal). I have done my rear passenger windows like this and had no issues. I cleaned up the edges with a fine file and a bit of sandpaper.
              Maule M5-235C C-GJFK (Sold)
              RV-8 C-GURV (Sold)
                Sounds like the need is for detail cuts in curves. Long straight cuts are great on a table saw.
                  The table saw I have access to is not able to make a 17” wide cut.
                  I put a new blade in the pneumatic jigsaw and the cutting was much easier and I got the results I needed
