My Matco install is below, parking break engaged as shown. It uses a camshaft, springs, and valves.
If I were to do it again I would raise the brake valve so there was no chance of contact with the right co-pilot's foot. As it is I think it will be fine, the open position has the arm down and I can see it easily while seated. Having a parking break in-line with my mains as opposed to a separate master cylinder, I want to be able to visually check it is disengaged.
I finally got around to disassembling my valve to figure out why it was seeping through the arm. The inside edges of the valve are very sharp and its easy to slice a piece of the o-ring off when installing the camshaft. Mine came from the factory this way so I wonder if this is a common issue, if folks don't notice, or what. I was able to get the same o-rings from my local ACE aircraft section, they are a common size that I don't remember off the top of my head but they are easy to find.
Works great now and no seepage at all, I'm using generic ATF for those who care.
Dave
Dave
