Where did you guys mount your comm antennas? I think I saw Jared had his mounted to the wing not far from the root. Is there any disadvantage to other locations?
How about ELT? I've seen some people do them internally just inside the fabric, but range may be hampered by being inside the fuselage. The argument is that if the aircraft is on its back, the antenna could be broken off anyway. Thoughts?
Transponder is generally the stubby on the belly.
No plan for a VOR antenna.
Thanks.
Thanks.
