Double check everything
  • Double check everything
    Getting ready for a fuel flow test I started adding fuel to the main wing tanks, pouring from a 5 gal fuel can. I poured about 1/2 of the can into the left tank when it occured to me to stop and look for leaks. Turned out I had a puddle quickly growing under the left gear leg. I quickly removed fasteners to lift the lower part of the boot cowl skin to access the 3/8th T fitting. Turned out the line coming from the front fuel pick up wasn't even finger tight. I have no idea how I missed that. I have torqued and torque sealed virtually every bolt and fitting in the plane, but not that T fitting. Somehow I had covered it up before verifying it was secure. I pulled up the boot cowl on the other side and the T fitting was properly torqued and sealed. In hindsight, if I wasn't so sure everything was good, I would have gone slower with the initial fill, checking for leaks. On the bright side, so far no other leaks in either homebuilt tank or the rest of the system.
    Good catch Rod…it happens. I remember helping a friend getting ready for a first flight. I looked over all the fasteners and found an aileron bolt with a nut just partially screwed on.​
    FWIW, I pressure tested my fuel system from the wing root fittings to engine fuel pump inlet fitting. I capped everything, put on a gauge, pressurized it and let it sit overnight.
