As I work my way through the door skinning process, I would like some experienced insight from the group. This is on a Patrol and would like to know what to do with this small piece of skin above the top hinge arm (pic), also the builders manual calls for bending the top edge of the skin over the top door frame tube to cover the tube. I'm thinking of snipping off the small piece of skin and doing the 90 degree bend over the top door frame tube in place after riveting the skin to door frame. What holds that 90 bend to the top of the tube, adhesive of sorts? Also consideringthe use of Pro Seal to fillet and blend the cut allowances for the hinge arms. Open to any other ideas. Many thanks! (Dave from Maine)
