Just to clarify-- the airfoil shaped ribs dont have the turned-edge--- only the "flat" ribs in the rudder and elevators. The stab ribs are the curved ones- and those are made on form blocks and dont have the turned lip. The parts Im trying to mfg are the exact ones in Rob's two pictures. Maybe i'm trying to turn
that lip at too much of an angle. Cant turn it too far in the brake because it its the hold down bar on the trailing edge end if it turns too far. im still on the struggle bus trying to get the widths exactly right at front and rear (template vs bent steel)
I found that Cleveland Aircraft tool has an edge forming tool that has two rollers welded to a vise grip designed for turning a flat on edges. Unfortunately it's shafts are facing the wrong way to get it inside the box section-- and the whole thing is too big and they dont make a Jr. sized one.
Rob: did you taper the width of the turned edge as it goes towards the small end ? That seems to be what the material wants me to do----
im using a 1/4 or 5/16 hold down bar on the brake--- so when you insert the 3 sided shape to make that final shallow edge bend-- the hold-down is about hitting the material before you start the bend. if I tapered the lip a bit that might relieve that interference.
I have a sheet of .025 4130 from spruce I have not cut into yet. I am currently using (possibly practicing on :-) ) .030 1008 from the box store. Seems to be bending well (cross grain bends)
PS---- I think at some point they went to lofted ribs on all the models for the stabs. (instead of just round tubing) But all the rudder and elevator ribs have non-curved steel ribs with turned flanges.
