Install the wheel and decide on an orientation and tension for the nut. Mark a sharpie line across the axle and nut. Count the turns as you remove the nut and wheel. Reinstall the nut without the wheel, countng your turns until you restore the nut's desired position. Clamp the nut to prevent rotation. Drill and debur from the outside of each axle, using the nut as a guide.
