(Untitled)
In the process of finishing most of a quick-build kit with a Lycoming engine, I've realized that there is significant opportunity cost to building an airplane, even if one uses a quick-build kit and the engine that the airplane was designed for. Spending 1700 hours on building means not spending 1700 hours doing any number of other things. Spending 3500 hours, well, that's a lot of hiking/camping/gardening/learning/etc. I think of this in the context of having a young family myself. If you were to complete a Bearhawk-inspired radial airplane, it would be quite a feat and no doubt a recreational and educational experience. But if your goal is to have quality experiences with your family, odds are that you will have failed at that goal. If you are able to get the family involved enough in the construction, and teach them the math and science so that they could do the engineering, then maybe this will not be the case- but I think a truly honest assessment will lead to the conclusion that the path to building a "plain old Lycoming" Bearhawk is still a very long path. Keep in mind that the Bearhawk has very good performance, even with the 360 that it was designed around. The 540 is a real hot-rod option that usually comes with a price premium on the order of $10k initially, and and empty weight penalty of around 100 pounds. Then there is the ongoing cost of fuel consumption- even if you throttle it way back for cruise to get the burn of a 360, you'll still have the high fuel flow at takeoff power. Lots of folks have gone with the 540, but don't let that lead you to believe that the bottom of your engine choice spectrum should be the 540. I think it's less of a starting point, and more of an ending point. If the sound of the engine is enough to make you want to go through all of that expense and hassle, you could save time and money by a factor of 10 or more, and just make up a speaker system that plays radial engine sound and even machine guns. On the topic of other engines, my unscientific count shows more Bearhawks that have been converted from other engines to Lycomings than Bearhawks that are happily flying with non-Lycoming/Continental engines. I don't want to come across as being poopy-pants about innovation and dreams. Rather, just to point out that building has a high cost, that can be made much higher by choosing an engine that nobody else will have. Add in that you'll have an airplane that is likely to be operationally inferior to the one that would have been easier and cheaper to build, with exceptions that I can count on half of one hand.
