Gary Wallace
Well-known member
Has anyone used flush stainless blind rivets on ail and flap trailing edges and if so where are they available. Also, has anyone used same flush rivets on aileron nose ribs into counter weight tube? Thanks again
Flush stainless steel riveting have been trying to source them but not having any luck. Any idea where I would find them???
Setting aside corrosion concerns, stainless steel materials are roughly 3x more dense than aluminum. The resulting weight would need to be considered.
Also consider shear strength; taken from a pretty good article (http://machinedesign.com/materials/c...d-other-metals).
"Shear strength, the maximum stress a material endures before it fractures, comes into play when components see off-axis forces. Shear strengths are not typically quoted for stainless steels because they are too low to have engineering value. 4130 alloy steel has shear strength around 11 ksi, lower than those for the aluminum alloys."
Changing to stainless steel hardware alone doesn't provide any additional corrosion protection aside from the actual piece of hardware. It is more likely to cause additional corrosion in the contacting materials than regular alloy steel. Looking at a galvanic series chart shows the substantial differential between stainless and aluminum.
Help me understand Blind Rivet Selection.
I would think an Aluminum blind rivet would be the rivet of choice for attaching two aluminum parts, and SS rivet for attaching things with dissimilar metals like the steel balance tube. In the Patrol Plans, Bob specifies "SS Pop Rivets" for the Balance Tube attachment, and merely "Pop Rivets" for the Aileron Pocket Skin.
Thanks Battson for the reminder about dissimilar metal corrosion, and ways to mitigate it. With that mind, is it prudent or negligent to use SS Pop Rivets throughout if we observe corrosion mitigation strategies? What is the "Best Standardize Practice" for us to employ?
How does one rivet the counter weight tubes with pull rivets since these are filled with lead and 3/4" in dia ?
(snip) They work quite well. I'll take the link from SpruceForest and buy a 3/32" version from Spruce. Those look a bit less 'redneck' than mine
