I had a venting issue where my engine was not getting enough fuel. We (two buddies who are airplane builders and myself) were scratching our heads trying to figure out why my engine would not start., so we:
1) removed the fuel hose from the carburetor to find only a few drips of fuel
2) removed the fuel hose from the fuel flow transducer.. only a few drips of fuel
The above two eliminated an issue in the transducer to carb hose
3) removed the transducer (gold cube), and only a few drips of fuel
#3 elimated the idea of blockage in the transducer
So we were all scratching our heads trying to figure out the problem, and without saying a thing I stepped up on the tire and removed the fuel cap…. The fuel started flowing like a fire hose.
At that point we knew it was a venting issue. I called Virgil and discussed it with him, I was going on a work trip so sent my caps to Virgil and he drilled them out. I got back, put them on and my fuel flow was outstanding.
NOTE: Yes I did a fuel flow test prior to this episode, but I must have done it with the fuel caps removed and my flow test was well over 30 GPH
This venting problem was on engine start for a brake break in taxi run. Funny enough we had an issue on the initial engine run and thought maybe the fuel how was blocked, so we blew air up the fuel line from the carb connection backwards and the engine started.
