I need to add a story here from the "not particularly proud to tell it" category. But I'm going to fess up because it may save someone else for doing the same.
A couple of months ago I took the Bearhawk on a solo trip the lake to tow paragliders. It's a 3-hour drive or a 1-hour flight. It's a great airplane mission, because the weather demands of paragliders are much more stringent than GA planes, so weather isn't usually much of a concern. I secured permission to tie down at a tiny airport with no attendance or services at all. It's very much like the airport where we keep our airplane, and best of all, it is really close to the boat ramp we use for the towing. The morning flight over was easy. I knew I was going to have to fuel before getting home that evening, but I didn't fuel in the morning, and parked the plane with around 12 gallons on board. That's not much, but it is certainly enough to fly a few miles to the big self-serve airport on the way home.
Having snacked/worked through lunch, we had a great day and were pounding away some much needed calories at the Mexican place. I happened to check the radar image on my phone, and there was a giant line of rain that was headed right for us. The line was parallel to my course home, and probably 40 miles upwind. I didn't have to get home, and knew that. But I also had a hunch that if I hustled over to the airport and got on my way, I'd have a good chance to make it home. It was safe in the sense that the line was barely moving, so I could always make a right turn and be in clear blue sky. If the rain moved over the home airport, I might have an adventure, which is no big deal.
The hop over to the big airport was uneventful, but I knew that time was not on my side. I figured, why not just fill up the right tank? That would be 17 more gallons than I'd need to get home, and over the course of the flight, it would be able to drain itself to the left tank. I'd save the time of having to move the ladder over to the other side, and be on my way 5 minutes sooner.
Skip ahead 15 minutes or so. I was on the radio with Greer approach, flying on course and parallel to an ominous looking line to the left, with a perfect day on the right. I could see the rain falling hard to the left, right at the Blue Ridge Escarpment. I was feeling pretty good about surfing the updraft curling around from that upflow, set at my usual 8gph cruise power and getting a bonus 20-25 knots of IAS over the usual cruise. (note! This technique is not recommended for beginners. Or really for anyone else. It's not the first time I've done it, but it's not without risk.)
I did a cursory and typical check of the fuel sight gauges and got quite a surprise. The left tank was as empty as I've ever seen it, and the right tank was still completely full. This is not what I was expecting, since I'd had some time for the tanks to balance. The left tank level was actually going down, not up!
At this point, my brain was showing the little hourglass symbol. Thankfully and perhaps luckily, I came up with a hypothesis. What if, in my slightly rushed refueling, I forgot to replace the cap? The left tank would have positive pressure, the right tank would have at best ambient pressure, and maybe low pressure. The corrective action that I needed, perhaps very quickly, was to select the right tank only. The pressure in the right tank was lower than the pressure in the left tank, but not so low that the engine wouldn't run. To confirm this, I selected the right tank with a close watch on the fuel flow, and thankfully it never changed. Everything was still good, and I pressed on towards home.
As I got closer, I could see that the rain had not reached home yet. I landed in strong gusty winds, which is also not recommended for beginners or anyone else. But I put the plane away and checked the right tank. Sure enough, the cap was gone.
So while I don't expect that I'll be adding a cross vent in the near term, I do want to point out that I encountered a scenario where the designed system was not tolerant of a particular series of errors- that is, fueling only one tank, and failing to recap the tank. It is totally fair that the system does not need to be tolerant of these errors. It may very well be that the engine would have kept on running. I wasn't in a position to test it.
As I said in the beginning, this isn't a story of great piloting. But I thought it was worth sharing.
