I put an Airflow performance FM250 system on my 540. Price was $3000 but that was 2010 dollars so probably a meaningless number now. As far as the process, it was straightforward. AFP provides a very detailed installation/operation manual. I decided I wanted horizontal induction for a sleeker cowl and hopefully some ram air effect. That involved some nose bowl fiberglass work to accomplish. I highly recommend fuel injection, makes running lean of peak easy. Following the recommended procedure for hot starts in the Lycoming engine manual, I have never had a problem with them. I would do some research into what options are available today.Has anyone converted their carbureted 540 engine to fuel injected? Curious about the process and cost…
Yes, the engine had the original fuel spider with lines to each cylinder. Easy to swap out to the electronic fuel injectors.Hopefully you have "injected" cylinders. Ports on the upper side of the cylinder for FI. They can be added later. I had to do it on 2 cylinders.
BTW I love the idea of 2 electric pumps. They are 120 dollars each and this would might make hot starts less of an issue.
