Glenn Patterson
BH-4 #727
Would any builders who used 3/8" fuel lines & did the fuel flow tests with please let me know what their flow results were.
We are installing a Continental IO-360 with a positive displacement engine driven pump that pushes 160 lb/hr at full throttle. FAR 23 requires the fuel supply to be 125% more than the circulating pump which requires a supply of 200 lb/hr. The engine actually burns 110 lb/hr at full throttle and returns 50 lb/hr. FAR 23 is trying to prevent pump starvation and using it as a companion to the AC90.89A for preflight requirements.
3/8 tubing feeds Lycoming 540's with no issues so I don't expect to have an issue with fuel flow. I am just trying to get a handle on the fuel system capacity as Barrow designed it.
Your help is appreciated. Thanks
Glenn
BH727
Glenn
BH727
