In my opinion, the problem is being solved the wrong way. The problem, as I understand it, and discussed with Battson at the time I was locating my pedal assembly to drill, is this:
The rudder pedal
not being depressed rotates away from the firewall, and if the same brake pedal is simultaneously depressed too far, will trip over-center where the master cylinder attaches to it. This allows the master cylinder to cam in place like a chair-back leaned against a door knob. In order to remedy this situation, one would have to reach down and pull up on the brake pedal to pull it back over center of the cylinder.
Just took a quick video as my Bearhawk is in my garage:
https://www.youtube.com/watch?v=dF6NGosgbfw
Sorry Battson, no time to add Doobie Brothers.
This is clearly a safety issue, as 1) no one wants a stuff rudder pedal, and 2) no one wants a brake stuck on. However, I question the practical situation where this might really occur. It seems a primed and properly bled brake line wouldn't allow such a deep compression of the master cylinder in the first place, though the further the rudder pedal rotates aft, the less the cylinder must depress for this to occur.
Current solutions address placement such that the rudder pedals bottom out against the firewall, but I think the solution is to weld a stop on the backside of the brake pedal arm itself, which bottoms against the rudder pedal, limiting the brake pedal travel. One could simply reshape the attach bracket that is already being welded on there to extend down and provide the stop.
Just my opinion of course, sitting here at my desk with only mind main and memory to serve me.
