noema
Stefan Hechenberger
I recently trimmed out my Bearhawk Patrol for hands-free (and feet-free) flying. It's remarkable how little modification it took to go from okay-ish to dialed in.
I started with a light 6" angle extrusion taped to the rudder. This was comically too much trim. After reducing it to about 2 inches, the airplane completely balanced out. The issue was never concerning, but the plane would drift into a slowly increasing right turn. I couldn't tell whether it was mostly rudder or ailerons/wing twist causing this. With slight pressure on the left rudder pedal, the airplane wouldn't fly well on autopilot, making very uncoordinated turns and taking long phases to get coordinated again. I basically couldn't tell if it would self-stabilize after an AP turn because of my manual correction. The manual correction in coordination with the AP is curiously much more awkward than with your own hand on the stick.
This had me concerned it would be a difficult issue to solve, and I questioned whether skipping a rudder servo was a mistake.
I'm happy to report that a little trim goes a long way, and a gurney flap accomplishes this beautifully and simply. My guess is there's a tipping point where the dihedral can no longer stabilize the airplane. It starts to feel off and the autopilot struggles with turns. Once you get it within what the dihedral can handle, the hands-free and autopilot flying normalizes.
At any rate, autopilot turns are completely normal now. The airplane automatically regains coordinated flight within three seconds. Also, when I place the airplane into a coordinated bank (20-30*), there's no auto-leveling and no tendency to increase bank. It is surprisingly sticky to the bank angle I set it to, hands-free. I really like it.
Thanks @way_up_north for his walk around and reassurance that gurney flaps are effective. They are a bit unintuitive.
https://youtu.be/kmw-Z-yymRI?si=J5zP54U81z9KGKyS&t=1290
